Torn ball joint boots on passenger side - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2012, 08:44 AM
dasyhard's Avatar
My 56 chevy which is prostreet has the Heidts 2" dropped spindles mounted. When I took the car for alignment the shop informed me that they couldn't align the tire on the passenger side to get a full turning radius because it was too low. I don't have a problem with not turning fully to the right but I do have a problem with my ball joints which are fairly new (less than a year old). The boots are torn as you can see from my pics. And the spindles don't seem like its meshing properly to the ball joints. A friend told me that I need to get heavier springs so the car rises an inch or 2 but I don't want to raise it. I like its current height. Any advice to fix this and prevent this damage from happening again would be appreciated.
ID:	66307   Click image for larger version
ID:	66308   Click image for larger version
ID:	66309   Click image for larger version
Old 06-25-2012, 09:22 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
How many miles on on your car? Have you overgreased them?
My Car has a Superide II, and I just took my Car apart and re-powdercoated eveything, and replaced all of the Boots (Ball Joints and Tie-Rods). Heidt's was happy to send me new ones-
I don't see anything different between yours and mine (other than the obvious torn Boot ), but I would just replace them-
Old 06-25-2012, 10:07 AM
Not necessarily cheap but raising the suspension and installing dropped spindles should correct everything and allow you to keep the front low.
Old 06-25-2012, 11:15 AM
Sometimes when the car is lowered by simply "shortening" the springs (which is essentially what you have) you change the geometry and the control arms are going up at an angle that is forcing the ball joints into a angle that it wasn't designed to work at. This is going to play hell with things and it simply isn't right.
All you need to do to correct the problem is to screw that spring seat up on the shock raising the front a little. This may not take an inch, it may only take a half inch but you need to take the extreme angle away from that ball joint, it wasn't designed to work that way.
Old 06-25-2012, 02:57 PM
dasyhard's Avatar
Thanks for your feedback. Just over 200 miles on the odometer since being restored and no I don't think I put too much grease. I will call Heidts for replacement boots.
Old 06-25-2012, 02:59 PM
dasyhard's Avatar
Thanks John.
Old 06-25-2012, 03:03 PM
dasyhard's Avatar
Thanks Brian, your analysis is exactly what I thought. I will apply your suggestion and see how it goes.
s10 ball joint/ 4runner ball joint stevetankl Suspension - Brakes - Steering 1 06-16-2012 02:59 AM
new ball joint boots cracked tech69 Suspension - Brakes - Steering 6 05-01-2011 10:25 AM
68 gto ball upper ball joint removal question adam83 Suspension - Brakes - Steering 25 01-04-2011 02:39 AM
Mustang II ball joint boots jaxhome Suspension - Brakes - Steering 24 04-04-2005 08:35 AM
upper ball joint boots yezek6 Suspension - Brakes - Steering 3 03-29-2005 05:25 PM
