Torpedo heater help !!
Got an old torpedo heater that's been working fine and just won't fire now.
I've been all thru everything. Got a good fog for the fuel,spark from pulling the plug and you can hear it buzzing with the fan/pump off when in place and I've checked the air pump filter and the fuel nozzle is fine. Not sure exactly what the gap should be on this plug but it's about 1/16".I've played with the gap but no luck, I'm thinking the coil is breaking down and it's just not a hot enough spark to fire it off. Any ideas? Last edited by Bee4Me; 12-09-2005 at 11:07 AM. |
Bee4me,
when mine did this I found that the Propane Regulator had failed (I assume yours is Propane? Craig |
No,sorry, It's a fuel oil one. Kero or #1.
I have had to take mine apart several times and clean out the pump part. It actually draws the fuel only when the fan is running. The pump gets dirty and will not draw fuel. They really don't take much spark to fire off. If you are sure it is getting fuel, the ignitor may have gone bad. Try lighting it with a propane torch from in front. Make sure you are standing on the side when you do this! If it lights, then check to make sure you are actually getting spark. The ignitor in one that I had went bad. It sounde like it was sparking, but it really wasn't.
Aaron |
| Recent Garage - Tools posts with photos |
| Need help deciding on garage heater | Xenocide | Garage - Tools | 20 | 01-05-2008 09:54 AM |
| Using copper pipe for heater lines | Jag Daddy | Engine | 1 | 02-09-2004 05:21 PM |
| Heater has mysteriously stopped working. | HotRodMan | General Rodding Tech | 8 | 12-29-2003 04:38 AM |
| painting in garage... water heater concerns? | Eddie N | Garage - Tools | 18 | 03-09-2003 08:06 AM |
| Heater control valve question | HotRodF100 | Engine | 2 | 05-23-2002 03:15 PM |
