Torque Conv shimming question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2008, 02:45 PM
Slomotion34's Avatar
Last journal entry: Mini Tubbing a 1967 Firebird Convertible Part 1
I just got done installing my torque converter and the shims that I have are 7/16" center holes (that's all that Jeg's offered... or 1/2"). The bolts are 3/8". Is this going to be a problem? Isn't all GM 3/8"? You'd think a 3/8" shim would be standard. If it was just one shim, I wouldn't be so concerned, but since I am shimming .250" for a mid plate and the converter needed another .125" to put the converter at 1.125" or so (Hard to get a good measurement installed) from the trans housing edge, it's got me a little worried. I did use new grade 8 bolts, but dang, that's a lot of shim. I've never had a mid plate, so I am concerned that I am doing something wrong.... the tq conv is a B&M 10" used, and the "nose" doesn't stick in the flywheel like it did in the car it came out of. I just don't want to fry anything in the tranny or shear off bolts (or worse). Thanks.
Old 06-15-2008, 02:53 PM
Notorious's Avatar
Hot rodder, not street rodder!
That is a lot of shimming so I understand your concern. All older GM trannys are 3/8" I think but some later ones use 10mm bolts, I believe. I'm pretty sure that's what my 4L60E uses for converter bolts.
Old 06-15-2008, 04:20 PM
ericnova72's Avatar
More for Less Racer
converter shimming
The amount of shim isn't that bad, but the fact that the nose of the converter doesn't fit up into the pilot area of the crank is a BIG problem. Converters made for use with a mid plate have a longer nose on them for this reason. Some even have a screw-on nose so that they can be altered if needed. You need to send the converter out and have this issue fixed. Probably not what you wanted to hear.
Old 06-15-2008, 08:18 PM
Better to hear it now.... thanks, I'm going to pull it out. Wow, I never knew that the mid plate involved more than just shimming the converter. At least this is getting caught before it's running!
Old 06-15-2008, 08:50 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
as mentioned... the converter MUST be built for the size of mid plate if one is used... very important
1/8 and 1/4 inch are very common mid-plate sizes
Build for Hp or Torque? Venturat Engine 76 09-23-2008 11:22 AM
Torque Converter Question newbielike Transmission - Rearend 2 12-17-2007 06:53 PM
Torque conv. stall? 327NUT Transmission - Rearend 3 01-11-2007 12:41 PM
Hotrodders Guidelines -- READ ME Jon Electrical 0 06-14-2003 06:01 PM
Hotrodders Guidelines -- READ ME Jon Body - Exterior 0 06-14-2003 06:00 PM
