Torque conv. stall? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2007, 09:27 PM
327NUT's Avatar
Torque conv. stall?
I just need a reasonable guess on what my torque converters stall may be. I had a very good friend who's been building transmissions for 29 years completely go through my '90 700R4. He supplied me with a reman. 4.3 ltr. V6 converter. He gets these from one of his cronies who owns the converter shop. He has them specially built with heavy duty parts and funace brazed fins and says they work great in street rods. He said its rated at 1800 rpm so I,m wondering what the stall would be for my 331" sbc with Edelbrock alum. heads, Comp XE262H-10 cam, 9.50:1 comp, Edelbrock rpm air gap and 600 4150 Holley. The desk top dyno showed it at 349 hp @ 5500 rpm / 385 lb.ft. @ 4000 w/ closed exhaust. I,m thinking maybe 2200-2300, what do you guys think?? thanks, Dave
Old 01-10-2007, 09:57 PM
that is good but will be doggy off the line at the dragstrip if you are going to race it. but it will good for street driving
Old 01-10-2007, 10:21 PM
327NUT's Avatar
NO, no race car, Its a '32 Ford Victoria, built for croooozing. I dont think it will be too "doggy" off the line, 3.06 first gear going out to a 3.89 9" 31 spline 4 pinion posi. ... probably light 'em up pretty good ifin I wanted to.
Old 01-11-2007, 12:41 PM
valve body kits
could be as hi as 2600-2800. it's hard to say because there are so many variables that are unknown, like , impeller blade angle (3 different common pitches), which stator does it have, how much clearance between turbine and impeller, is he cutting back the stator, and how much. etc etc.
just put it in and find out!
Dean
what would be the best stall converter for me? tiresmoke55 Transmission - Rearend 3 08-30-2006 04:42 AM
Higher stall torque converter = less power? 84Z Transmission - Rearend 1 10-06-2005 02:20 PM
which stall to use.. Lthompson Transmission - Rearend 6 02-08-2005 04:31 PM
Torque Converters: Do They Multiply Torque? purple1967camaro Transmission - Rearend 1 04-28-2004 11:41 PM
Stall Speed? drlindz Transmission - Rearend 2 08-25-2003 03:40 PM
