torque converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2007, 04:56 PM
torque converter
hey all is it possible and okay to put a th350 torque converter in a th400 behind a 472 caddy? because i've looked everywhere and can't find the same torque converter that i have in it now.
Old 09-27-2007, 06:15 PM
The converter will fit the trans. It requires that the flywheel have the narrow bolt pattern for a 12" converter as the stock converter is 13"....
Better double check!
Old 09-27-2007, 09:34 PM
dang that was quick, thanks alot man.
Old 09-27-2007, 10:13 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the 472 & 500 cid caddy flywheels I have seen, only have the large bolt pattern for the 13 inch diameter converter
check it as chazmac points out!
Torque converter question sam83k10 Transmission - Rearend 7 08-09-2007 07:23 PM
Building a SBC to rev to 8k, and have power Andyrew Engine 52 04-17-2006 12:46 PM
Torque Converter Failure - TH350 blown81 Transmission - Rearend 1 10-16-2005 11:41 AM
Torque converter, diesel vs gas pjd Transmission - Rearend 4 09-10-2005 08:52 PM
Torque Converter to Flexplate 41willys Transmission - Rearend 2 11-01-2002 02:58 PM
