torque converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2008, 10:01 AM
torque converter
hi everyone,
after the engine and transmission swap (350-th350), i saw that the trans shift on third after 75 feet.
i've used a stock torque converter for the max low end torque but with a 5.99:1 diff ratio and an 280 hp Engine it's probably too much.
i'm considering to get it off and replace with a new one but i don't know too much about stall speed.
probably a 3000+ converter should be better but i want to hear that form you!
thank you in advance.
Old 05-09-2008, 09:24 PM
stfinney's Avatar
What cam are you using? What's the power band if the cam? That tells alot about what torque converter to get. I think 5.99 gears is a bit much, yeah!
Old 05-09-2008, 11:30 PM
SSedan64's Avatar
You could probably use a governor recalibration kit too. It wiil help lengthen the time and speed that the transmission shifts at. With those rear gears I'm suprised it takes 75ft to hit 3rd.
Old 05-10-2008, 01:16 AM
thank you for the reply guys...
sorry i'm forgot some detail, the cam is the Edelbrock 2102 performer plus and there's a trans-go shift kit in the transmission, i've took off the little spring in the modulator but seems to be the same thing as before.
i don't pretend to have the perfect shift but just a little better, my idea is to grab a new converter eith something like a 3000+ stall, so what's your opinion?
thank you again.
Old 05-10-2008, 01:39 AM
SSedan64's Avatar
The 2102 cam is recommended for Idle-5500rpm. You shouldn't need 3000 stall unless you plan to get a much larger cam. A stock stall should work geat with the 2102 cam. What type car do you have the 350/Th350 in? What do you intend to use it for?
Old 05-10-2008, 11:03 AM
i know you're gonna hate me, is a Jeep CJ-7, built for almost just off road use...
i've the stock converter right now and it's not good, the rearend ratio is the first problem now...
700R4 Torque Converter Flexplate Question fosterdl Transmission - Rearend 8 03-23-2008 12:03 PM
Torque Converter Question newbielike Transmission - Rearend 2 12-17-2007 05:53 PM
Torque converter question sam83k10 Transmission - Rearend 7 08-09-2007 07:23 PM
Torque Converter Failure - TH350 blown81 Transmission - Rearend 1 10-16-2005 11:41 AM
Torque converter, diesel vs gas pjd Transmission - Rearend 4 09-10-2005 08:52 PM
