torque converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2003, 12:21 AM
spankthru's Avatar
iron head
torque converter
well, i got my engine pretty much done, but i ran out of money and had to throw in a stock torque converter, when i do get the money, ill be getting one around 3200-3500 all ive heard is that i had _better_ get a trans. cooler, any other things i should know about, one guy even told me it would eventually tear up my engine or trans. with that high of a stall, can anyone give me any info?
Old 09-29-2003, 04:13 AM
Frisco's Avatar
Glad To Be Here
Re: torque converter
You didn't say what cam you have in your engine. If it is a fairly high lift you may have some problems with the stock stall torque converter. This is because the idle RPM required for the cam may be very close or over the stock stall speed. The converter will then be trying to 'move' the car and you will have to keep a very firm pressure on your brakes or put the car in neutral whenever you come to a stop.
If you think you really need a 3200-3500 RPM stall speed; I'd suggest you wait to drive the car until you have installed a higher stall converter.
A separate trans cooler is always a good idea; even with a stock converter. For a street car I'd keep the stall speed just below the operating RPM of the engine when cruising at freeway speed. i.e. If you are running around 3000 RPM at 65 MPH then don't use more than a 2800 RPM stall. Keep in mind that the heavier the vehicle the stall speed of the converter will be in the upper range of the advertised stall RPM.
Old 09-29-2003, 01:38 PM
spankthru's Avatar
iron head
sorry, my cam is a .519" intake lift, (comp xtreme engergy 294H)
yeah i have to put the car in neutral at a stop, or keep slight throttle opening or it will die
