Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - torque converter for 283 in a jeep
  #16 (permalink)
Old 11-12-2012, 08:56 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
its advance and retard not before and after.
disconnect the vacuum advance and set the timing to 30deg advance using a timing light.
reset the carb idle speed to 900rpm and readjust the idle mix screws for best idle . what is the manifold vaccum at 900rpm>
do not drive the vehicle with the timing set so.. just tell the intake manfold vacuum.
