torque converter for 283 in a jeep - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-12-2012, 08:56 PM
F-BIRD'88's Avatar
Yada Yada Yada
its advance and retard not before and after.
disconnect the vacuum advance and set the timing to 30deg advance using a timing light.
reset the carb idle speed to 900rpm and readjust the idle mix screws for best idle . what is the manifold vaccum at 900rpm>
do not drive the vehicle with the timing set so.. just tell the intake manfold vacuum.
Need Bolt Torque Specs For A 2.5 Ohv In A '95 Jeep adantessr Engine 4 05-26-2012 10:28 AM
4l60e torque converter clutch torque capacity rx191 Transmission - Rearend 1 04-05-2011 04:03 AM
Torque Converter to Flexplate Torque Spec. Needed - 2004R Zeeb Transmission - Rearend 1 05-26-2010 06:47 AM
283 torque? itsa64 Engine 24 11-17-2009 10:07 PM
B&M Torkmaster 2400 rpm stall converter vs. stock torque converter??? zbhover Transmission - Rearend 2 11-02-2008 07:52 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
