-   -   torque converter for 283 in a jeep (http://www.hotrodders.com/forum/torque-converter-283-jeep-225984.html)
Jeepracer427 11-11-2012 07:24 PM
hi, i just recently changed the motor out of my jeep with a 283. the 283 came out of a 67 chevelle.
what i know about the motor-
-it is cammed (not sure on specs)
-it has the factory 4 bbl intake
-an edelbrock 1406
-power pack heads
-hei distributor
i have a th350, dana 300 t/c and factory gearing (have to check on ratio's)
im also not sure what the stall speed on the converter because the guy i got it off said it was just a factory stall. i previously had a 305 in it (thats what he got the converter for). it is a real dog taking off (almost to the point where it stalls) but when it gets to about 15-20 mph and i hit the gas, it takes off pretty hard.
my theory is the 305 had the torque at lower rpms unlike the 283, and it is not allowing it to move. any ideas? do i need a higher stall? or is there something else?
DoubleVision 11-11-2012 07:37 PM
1 Attachment(s)
Remove the carb and study the intake. If it's the factory 4 barrel intake of that year, then it will have a hole on both sides of the intake, in front of the primary side. These 2 holes will be connected by a trough. These holes are connected to the heat riser passage of the heads. The job it has is to heat the carb for easier starting and to prevent butterfly icing in cold weather. If a standard carb gasket was used, these 2 holes are open and they push exhaust gas into the incoming fuel mixture, greatly diluting it and robbing power because exhaust gasses cannot be burned twice. These intakes require a special gasket which was paper gasket on the bottom, a thin aluminum plate, then another paper gasket. This seals off the holes so it just heats the carb, the exhaust gasses are blocked from entering the incoming air mixture. Check to see if your intake has this gasket, if it does not that's half it's problem. The picture I'm attaching isn't the intake you have, but the example is the same.
vinniekq2 11-11-2012 08:55 PM
283 in a jeep,sounds like fun.try and find out your gear ratios and specs on camshaft..We had an old willeys jeep with a 283 and a standard in our shop years ago.It had 5.13s in the rear,in low range and first gear it barely moved.
cobalt327 11-11-2012 09:34 PM
-an edelbrock 1406
-power pack heads
-hei distributor
The first thing I would do is get the timing advance curve worked out. More on that here. Because if the timing isn't right, it will not run right even w/a looser torque converter.
I'm sure you're familiar w/the term "lope" when talking about the idle quality of a cammed up engine. Does the engine have a lot of lope or does it idle relatively smoothly? You should use a vacuum gauge and see what the idle vacuum is- that will also give an idea of the size of the cam.
Jeepracer427 11-12-2012 02:42 PM
Well I went and checked some other things. My timing tab seems to be flipped in the sense that where most tabs would have a b or befor is where my a is. Same thing as where my b is. I don't know how much the lines on it are because it only has a zero. When I put my vacuum gauge on, at idle it reads 5in hg vacuum. Finally I checked my gear ratio...it is coming in at about 1.3/1 (one and one third driveshaft rotation to tire rotation). That doesn't seem right at all?? I forgot to mention the tire size is 32 inches.
vinniekq2 11-12-2012 02:49 PM
still not much information.what would you like when the project is finished? did you like the way it performed with the 305?
DoubleVision 11-12-2012 03:44 PM
I would hope that you paid some attention to my post, I didn't post it for nothing. What I asked you to check is simple and if in fact the holes in the intake are left open it will cause all kinds of tuning headaches that you won't be able to cure no matter where you set the timing or the tune.
cobalt327 11-12-2012 04:28 PM
There were three commonly used dampers and timing tabs. Almost any damper can be used w/the wrong timing tab and that gives a false timing reading. To figure yours out and correct things if needed, see the page here.
To figure out the gear ratio you can use several different procedures, more here.
BTW, I know sometimes getting a bunch of links can seem like I'm "mailing it in". Trust me when I say that it's about the only way I can cover a large amount of territory w/o taking up a huge amount of time and space on your thread. I trust you'll understand.
5 in/Hg is WAY low unless you have a way rad cam in there. I'm guessing you don't have and cannot get (or can you?) the original cam card that was shipped w/the cam.
Start out by verifying the timing marks are showing you true TDC. This is key. Then see what the timing really is if the lines were off.
Once that's done, set the initial timing (vacuum advance disconnected and line to engine plugged) to 24 degrees BTDC and see what the vacuum does. Now, you don't want to drive it like this because until the distributor is reworked, this will likely have the total timing too high. Timing too high causes detonation, and detonation kills engines. But as long as the engine isn't under a load- like when driven on the road- then you can over advance the timing w/o any damage to anything.
If it 'likes' 24 degrees, add some more just to see how the idle quality and vacuum reading responds. No need to go any higher than 36 degrees because that's all the timing you can run. This will give you a baseline to work from when it comes time to modify the distributor.
Jeepracer427 11-12-2012 07:23 PM
1 Attachment(s)
here is a picture of my timing tab. can someone enlighten me on the marks?
F-BIRD'88-i checked it when the driver side was down. i spun the wheel and got the same result as when i spun the driveshaft...1.33:1
DoubleVision-i have the spacer plate that covers these holes
cobalt327 11-12-2012 08:43 PM
BTDC and ATDC are bass akwards. It looks like each line equals 1 degree. You can check this by measuring from zero to 10 lines away. If they're 1 degree apart, the measurement should be from 1.88" to 2.5". The reason for the difference is the tab could be for different diameter dampers. The range I just gave covers dampers from 6" to 8" in diameter.
cobalt327 11-12-2012 08:53 PM
Your best bet is to see what damper you have, 2 o'clock, 2:30 o'clock or noon and go from there. You can make a timing tape and transfer the marks onto the damper, then use a simple pointer to indicate zero. The timing will then be read from the damper instead of the tiny tabs that don't have enough range to show you total timing and vacuum advance.
If it's a 2:00 damper, that's what most all the aftermarket timing tabs are made for. Buy one and bolt it on. If it's a noon damper, the timing tabs are usually all tack welded to the timing cover. The 2:30 damper can be found w/either tacked or bolted on tabs IIRC.
