torque converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2004, 08:45 PM
torque converter
I ordered a 168t flywheel and a 12" torquemaster 2000 from b&m from Summitt, i talked to the salesperson making sure that the bolt patterns would work. I received them today and the holes on the flywheel dont line up with the converter, its a dual bolt pattern flywheel, I only knew of a small and large bolt pattern is there a third? This is for a th-350.
Old 01-09-2004, 09:10 PM
DoubleVision's Avatar
there is only 2, either they sold you the wrong converter, or the flywheel was not drilled with the holes in the correct locations, I`d get another flywheel first and compare it, see if it lines up and go from there.
