torque converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2004, 07:40 PM
"70" Cougar's Avatar
Meat-Head Extroidenaire
torque converter
Thanks guys for the info... ya sorry its a 351 Cleavland ( .30 over Keith black pistons mild to hot cam ported & polished fully balanced 670 cfm street avenger ) so ya if its fine then ill just keep it cause im running a FMX trans and id rather have a C6 which ill put in once this one brakes. OK... beginner question ?? The stall converter only lets the power go to the wheels at the "specified" rpm RPM right ?
Old 08-19-2004, 10:08 PM
stu stu is offline
C6
Will take much more ponies to turn than the FMX.
You will lose about 60hp going to a C6.
Old 08-20-2004, 06:52 AM
brainsboy's Avatar
brains
I had ran a FMX on my 351 for years, It just didnt hold up very well. The only thing I liked about it, was I could replace all the clutches without pulling the transmission out of the car. After I got tired of rebuilding my transmission all the time I went to a C-6. I dont know about 60hp but it does take more power to run a C-6, I had lost about .2sec on the quarter from it, if you calculate it out, its only about 25-30hp difference. But like stu said the FMX may be ok for you, I was pushing well over 500hp.
Ben
Old 08-20-2004, 06:58 AM
stu stu is offline
FMX
Can handle just as many horsies as a C6 if done correctly.
Not wanting to start any arguments or suspicions of others mechanical abilities.
Just my .02 cents worth. Plus 47 years as a rebuilder.
Old 08-20-2004, 07:07 AM
you got it
i guess ill just keep it like it is then ... we'll see how long she'l hold up . thanx Brainsboy
Old 08-20-2004, 07:22 AM
brainsboy's Avatar
brains
More then welcome cougar70, good luck with it, by the way my wife has me cleaning out the garage this weekend, I think I may have some old Cleveland performance parts, if you want them you can PM me, Im into windsors now so have no use for them.
Ben
Stu I know you have 47 years experiance, I have read your other bosts here,....I mean posts... Im sure no one knows more then you about transmissions.
Old 08-20-2004, 07:23 AM
stu stu is offline
Info
HP loss in different transmissions.
Powerglide - 18
TH350 - 36
TH400 - 44
C6 - 55-60
C4 - 28
904 - 25
727 - 45
FMX - 25
I am not boasting. Just stating facts.
Old 08-20-2004, 07:24 AM
brainsboy's Avatar
brains
Re: Info
Powerglide - 18
TH350 - 36
TH400 - 44
C6 - 55-60
C4 - 28
904 - 25
727 - 45
FMX - 25
Not wanting to start arguments or suspicions of others mathematical abilitys. FMX=25 C6=60
25-60 = 35hp wow pretty close to what I said thanks Stu
Old 08-20-2004, 12:53 PM
stu stu is offline
Ok
I was merely stating some facts so he could make his own judgement.
Your mathematical abilities never entered the picture.
Enough said.
