Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Torque converter
Old 07-08-2006, 05:56 PM
65Stanger's Avatar
65Stanger 65Stanger is offline
Check the water, check the oil
When you last ran the car.... it all ran and engaged everything? When I fill up a tranny after I've put a transmission in a car fill up the transmission with a few quarts 4 or 5 or 6 depending on the size of the transmission and start it up. It will all flow into the torque converter and everywhere. Think about it logically... the pump pushes tranny fluid all throughout everything, torque converter included, and should fill it up at any time. What do you mean it shifts like it's supposed to but doesn't engage the driveline? When you put it in reverse you feel the car go into gear, but then it doesn't go anywhere? When the engine's running can you see the torque converter moving through the dust cover on the transmission? Is your driveshaft bolted up? Make sure that you have enough fluid in the transmission. Check the transmission fluid while it's running and in park, and make sure that it's full. If it's low, fill it up, and it will probably work great.
