Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Torque converter
Old 07-08-2006, 06:40 PM
65Stanger's Avatar
65Stanger 65Stanger is offline
Check the water, check the oil
Ah-ha. Sounds like it might be time to pull the tranny and take a look inside! No grinding or anything when you put it in gear just doesn't go into gear? Have you tried shifting it on the actual transmission with your hand to see if it goes into gear and it does have to do with your linkage?
