Yes I'm checking it while it is running, and I'm not sure if the trans has ever been put to use, I know the engine and tranny are brand new and the engine only has like 6 hours on it so I'm sure the same goes for the tranny. I'm going to pull off the torque converter and check and see if it has fluid. I was told that if the torque converter is dry it won't create a vacuum to suck more fluid into it?? Not sure if this is correct but I figure I might as well check.
