Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Torque converter
Old 07-10-2006, 07:33 PM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
i would pull a cooler line or bolt a guage onto the trans to see if there is line pressure.... easier than pulling the trans out at this point.
now........ it is possbile the pump of the trans has a clogged passage and not filling the converter. Sometimes if a trans sits outside long enough trash or rust can clog the passages of the pump , then it is over looked by the builder.
