Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Torque converter
Old 07-10-2006, 10:23 PM
supermankbk supermankbk is offline
Originally Posted by Crosley
i would pull a cooler line or bolt a guage onto the trans to see if there is line pressure.... easier than pulling the trans out at this point.
now........ it is possible the pump of the trans has a clogged passage and not filling the converter. Sometimes if a trans sits outside long enough trash or rust can clog the passages of the pump , then it is over looked by the builder.
Ya I took my oil pan and strainer off and cleaned them but they were both brand new, there was a little residue on the bottom of the oil pan but nothing big. Well I cleaned that out and blew the pump lines out. I check to see if it was pumping tranny fluid by taking receiving line on the radiator off and let the tranny fluid pump out a little bit. So the pump is pumping the fluid as far as I can tell.
