Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - torque converter banging??? Flywheel or tranny??
Old 09-03-2006, 08:04 AM
nissan's Avatar
nissan nissan is offline
Last journal entry: 1930 chevy ratrod pick-up
I had a chevelle that sounded like that and finally the flex plate gave out completely. it was cracked around the six bolts in the crank. if you unhook the coil an have someone crank the motor over watch the flex plate turn,it should not wobble or it is cracked.good luck
