if the converter bolts r tight, then i would look at the flexplate, could be cracked. since the 4.3 is basically a 5.7 with 2 cyls. cut off, theres no difference in the back of the blocks.and the 350 shouldnt have any real issues, so thats where id start looking 1st.. gl
torque converter banging???
I had a chevelle that sounded like that and finally the flex plate gave out completely. it was cracked around the six bolts in the crank. if you unhook the coil an have someone crank the motor over watch the flex plate turn,it should not wobble or it is cracked.good luck
alright. i will give that a shot. Im hoping its the flexplate or torque converter and not the tranny. I will disconnect the coil and turn it over and see what happens. Will post results. Thanks
T C banging
It sounds like the flywheel broke at the flange of the crank, I have seen this happen a few times. And as far as the metal piece that you found, check the starter, there is a piece there that limits the travel of the bendix and it is probaly what that piece of metal was or part of it. Hope this helps, good luck, Happy wrenching!!!,
, Perry.
hey guys
thanks for the help but no one was right. LoL It turns out that the flywheel bolts didnt have the washers on them, so the fywheel bolts backed out about an 1/8th each and the flywheel was really sloppy, but some of them were still tight so when i moved the flywheel by hand you couldnt notice it. But when i found this out i just looked underneath to make sure once more and i seen the back of the crank imbetween the flywheel and i noticed the flywheel moved before the crank so thats when i started the tear down of the truck. But its fixed now, proper bolts and washers, starts and kills like a dream and the flywheel was not cracked at all. before i bought the truck the converter and flywheel were brand new. Thanks for the help! |
| torque converter to flexplate bolts?? | gavinpierce | Hotrodding Basics | 4 | 04-20-2006 04:25 PM |
| Torque Converter Failure - TH350 | blown81 | Transmission - Rearend | 1 | 10-16-2005 11:41 AM |
| Tranny update/Torque converter question | RObs71Nova | Transmission - Rearend | 5 | 12-16-2004 09:37 AM |
| Removing flywheel to converter bolts in a 1958 Chevy Impala 348 Cast Iron Powerglide | 1958imp348 | Transmission - Rearend | 9 | 11-22-2004 03:18 PM |
| C5 or Torque Converter Bad? | k2mooch | Transmission - Rearend | 2 | 11-30-2003 08:27 PM |
