Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Torque converter BB vs. SB
Old 04-08-2006, 08:47 AM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
Originally Posted by 6426yy
Maybe this isn't worth replying to but I'm kinka curious.
I pulled a 350/th400 combo out of a old suburban and I have a th400 in my 80 shortbed that was behind a 454, (still is but a different one.)
Now would the small block torque converter stall higher than the big block one if behind a big block? Just thought this might be a cheap trick.
A smaller diameter converter would stall slightly higher RPM than the larger one. The non lock t-350 converter and t-400 converter are swappable.
