Torque converter BB vs. SB - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2006, 07:25 PM
6426yy's Avatar
Maybe this isn't worth replying to but I'm kinka curious.
I pulled a 350/th400 combo out of a old suburban and I have a th400 in my 80 shortbed that was behind a 454, (still is but a different one.)
Now would the small block torque converter stall higher than the big block one if behind a big block? Just thought this might be a cheap trick.
Old 04-08-2006, 09:47 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
A smaller diameter converter would stall slightly higher RPM than the larger one. The non lock t-350 converter and t-400 converter are swappable.
Torque converter, diesel vs gas pjd Transmission - Rearend 4 09-10-2005 09:52 PM
Torque Converter Problem? 38project Transmission - Rearend 5 06-05-2005 03:21 AM
torque converter upgrade to avoid detonation? darom Engine 35 05-23-2005 07:48 PM
Torque Converter Question 79 Malibu327 Transmission - Rearend 2 05-27-2004 01:44 PM
Torque & HP for 355 SB Chevy bigjoedo Engine 7 04-17-2002 11:11 AM
