Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Torque converter bolt patterns
Old 05-09-2013, 10:56 AM
gearheadslife gearheadslife is offline
Banned
If iirc the g.m. th350/375/400 use the same bolt patern,
is the 7004r pattern the same.. is the 200r4 the same..
looked in the wiki links and did not find the bolt patterns..
I ask as I'll be needing a flexplate for my truck and like to get the correct one.. the engine isn't out to measure the t/c pattern and then go to parts store and check before I buy..
cause you know how this will work, I'll ASSume and after the store is closed, have to get another..
thanks..
