torque converter c6 what one? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2011, 09:45 PM
So I have a 79 F250 4x4 that I'm overhauling the c6. I've got the broader "500hp" overhaul kit plus a one way clutch and a extra forward drum friction and steel (to swap out wave plate). What torque converter do I use? There's so many... I just want a cheap stock one..
Greg
Old 10-07-2011, 11:02 PM
The Flyin Wop's Avatar
Paisano
Last wiki edit: How to remove an ignition key lock
Wiki Edits: 4
The higher the stall speed for a convertor usually means it will be smaller.Therefore less fluid,which will mean for the trans to run hotter.You could bump it up tp 2700 or maybe 3000 stall.But why bother unless you have a motor that's has some added zip to it.Why don't you have your convertor flushed and tested,or replace it with a oem.Just cause you put a shift kit,and some better cluches doesn't mean you got 500 hp.
Good luck,Paisano
Old 10-08-2011, 04:19 PM
Good luck,Paisano
See this is why I don't use the forums as much these days. Tired of all the silly answers.. I'm not gonna debate the strength of a c6 with aftermarket parts that I DID put in and you don't know about. Your post just wastes space and time. It didn't help me, not even a little.. You must not have read my post.. Posts like this make both me and you look just plain silly and that's not what I'm after. That's what the kit is called by broader (too bad you don't research before posting) if you really needed to know. It most certainly isn't the only thing done to this trans.. That isn't what this topic is about..
I don't want a higher stall in my stock F250 with a 351m. All I want is a stock one, problem is there's too many to choose from. If I get the measurements and find a low stall does it matter?
I understand how they work because of my BBC and am not asking about that.. I wanted to get a stock one from like napa but they don't carry that kinda stuff..
Example: when you search stock torque converter (all 12.5") it lists FM105, FM127, FM128 and more! Why is there so many? If I measure the bolt circle and pilot diameter and get a low stall that fits those specs does it matter what one I get?
Sorry if at first I seem rude. I just need the answer to this question and he didnt even come close to looking at my questions, I'm not looking for a higher stall torque converter. As I said just a cheap stock one (not weak as I tow) just stock.
Greg
Old 10-08-2011, 04:37 PM
Irelands child's Avatar
Why not take a wander over here to the FTE forum . Sometimes folks here forget that not everyone is into 1/4 mile drag racing and just need a simple question answered .
Myself, I would probably go a step higher then mushy stock - but that isn't what you asked
Dave W
Irelands child
Old 10-08-2011, 11:04 PM
SSedan64's Avatar
A slightly higher stall rating may be better if you're running large tires.
Looks like there are Apps. for Older FE engines, newer engines and Diesel engines.
http://www.makcotransmissionparts.com/C-6tc.html
I would think Advance, AutoZone etc.. or any Trans Shop could get you the correct TC.
4l60e torque converter clutch torque capacity rx191 Transmission - Rearend 1 04-05-2011 05:03 AM
Torque Converter to Flexplate Torque Spec. Needed - 2004R Zeeb Transmission - Rearend 1 05-26-2010 07:47 AM
Bellhousing bolts and torque converter bolts torque specs Davey3ch Transmission - Rearend 2 09-04-2009 12:05 PM
B&M Torkmaster 2400 rpm stall converter vs. stock torque converter??? zbhover Transmission - Rearend 2 11-02-2008 08:52 PM
torque converter SBCfan04 Transmission - Rearend 3 04-30-2008 01:15 PM
