Torque converter clutch
Could a guy make a fixture with an o-ring (exactly like the tip of the input shaft) to slide into the TC to air check the clutch. Not to see if it slips, but rather to check the condition of the apply piston to see if it holds air.
Are there bleed orifices in them? Should they hold pressure for a while? (4L60-E) |
You would be pushing off most converter clutches , not applying them
At the Bonneville Salt Flats, first gear is known as 130 mph. |
| Bellhousing bolts and torque converter bolts torque specs | Davey3ch | Transmission - Rearend | 2 | 09-04-2009 11:05 AM |
| Torque Converter Question | newbielike | Transmission - Rearend | 2 | 12-17-2007 05:53 PM |
| Torque converter question | sam83k10 | Transmission - Rearend | 7 | 08-09-2007 07:23 PM |
| Torque converter question(s) | chrisflock | Transmission - Rearend | 3 | 11-10-2006 11:41 AM |
| Building a SBC to rev to 8k, and have power | Andyrew | Engine | 52 | 04-17-2006 12:46 PM |
