torque converter to crank problem. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2013, 11:23 PM
Hellbilly Hotrods
so i got the motor and trans nestled down in the elky tonight. all is well and good, if things keep going well should have it back on the road by Monday.
problem is, the "snout" of the torque converter wont go into the hole in the back of the crank. so I cant get the bolts in.
I put the engine/trans in as a unit, as I figured that would be much easier.
trans/converter is an 85is 700r4, engine is a 73ish 350 that until last week was coupled to a stick.
can I pry on the converter to try to get it to pop in the crank snout?
is there something im missing?
I don't normally work on automatics (this is the first one I've ever reinstalled, actually. usually when I pull them out, a manual goes back in. never done the other direction), so I apologize if this is a newbie question.
I did make sure the converter was properly seated in the trans, and before getting the engine/trans mated (did not check after mating) and the converter slid in/out easily still.
what do I need to do? ill be back at the shop about lunchtime tomorrow.
Michael
Old 07-13-2013, 02:41 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Don't pry on it. The pilot bearing might be protruding enough to keep the converter snout from seating.
See Bushing Removal Methods
Old 07-13-2013, 04:58 AM
BOBCRMAN@aol.com's Avatar
Actually, the std trans pilot bearing must be removed from the end of the crank. For use with an automatic
Old 07-13-2013, 10:35 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
as mentioned , be careful , check for pilot bushing for manual transmittin in the crank. See my photo:
In this photo is a 350 chevy engine. GM crate engine I put in car 15 yrs ago, with T-350 behind it. Bushing is in far enough in crankshaft so no interference happens. The T-350 was behind a 305 engine for a while, so the T-350 trans has about 120k miles on it.
The Following User Says Thank You to Crosley For This Useful Post:
cobalt327 (07-13-2013)
Old 07-13-2013, 01:11 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Point is, there may or may not be interference from the pilot bearing/bushing- so check to see if there's anything sticking out beyond the end of the crank that could keep the converter from seating all the way.
Not saying it might not be a good idea to remove it anyway. Just saying.
Old 07-13-2013, 10:38 PM
Hellbilly Hotrods
pulled the pilot today. converter went in just fine afterwards.
hwo did y'all know I did that? painful experience like mine?
Old 07-13-2013, 10:48 PM
The key was. You stated there was a manual trans before. Very few people remember to pull the pilot bearing.
I bought a short bed pickup for very cheap one time. Same problem, but the guy just tightened everything down and couldn't start the engine..
possible torque converter problem xpsyclonex2002 Transmission - Rearend 20 02-18-2012 07:24 PM
C-6 torque converter problem? turchiac Transmission - Rearend 9 02-09-2011 10:25 PM
Torque converter problem??? blacklabzeke Transmission - Rearend 2 12-31-2008 04:55 PM
torque converter problem??I think yragat Transmission - Rearend 5 06-01-2008 09:46 PM
Torque Converter Problem Madhawk Transmission - Rearend 4 11-23-2004 09:35 PM
