Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Torque converter, diesel vs gas
Old 09-10-2005, 08:25 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
the t-400 only needs two (2) check balls in the correct locations to operate fine.
The diesel converter is a lower stall speed rating than a gasoline converter.
