Torque converter drain plug 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2007, 06:13 AM
blacklabzeke's Avatar
Is there a specific location to install a drain plug on a 700R4 torque converter?
Old 03-21-2007, 07:11 AM
kruzr's Avatar
street rods forever
That's a good question,why wouldnt they put one in to begin with
IMO I'm sure if one is installed,it will throw balance off...if not in right place
Old 03-21-2007, 09:22 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Nope.... the slight difference in weight would be easily absorbed by the rotating fluid in the converter.
now if a large plug was used , there would be trouble.
I do not recommend drilling a lock up clutch equipped converter.
It can be done ... carefully. Between fin ribs, NOT on the front of the converter shell
Torque converter -tranny guy is recommending........ ericbr Transmission - Rearend 1 01-04-2007 12:04 PM
Chevy Torque Converter Swap! leejoy Transmission - Rearend 7 01-04-2007 06:55 AM
Torque converter question(s) chrisflock Transmission - Rearend 3 11-10-2006 12:41 PM
Ford 4R70W torque converter interchange? sweet99 Transmission - Rearend 1 11-09-2006 04:04 PM
destroyed 1 torque converter hotrodjohn Transmission - Rearend 3 04-17-2005 12:23 PM
