Torque converter to far from flywheel
I swapped transmissions in my work truck 89 chevy 350 700-R4 and I have 3/8 inch space between converter and flywheel. I checked the knowledge base and found that 1/8 in is proper. But I could not find anything about the proper method of spacing. Is it OK to just use a couple of hardened flat washers and 1/4 inch longer flywheel bolts, or do I need to find one piece 1/4 inch spacers? Is this a common problem or should this be a red flag that something could be wrong with trans rebuild or converter.
MM |
Oops double post..
I just use washers that are Flat, I slide them over a file a few times to take off any high spots, I then measure the stack with a caliper and get all 3 stacks exactly the same. while you are under their you also may want to check the run-out of the flywheel you are using, and make sure their are no burs around the bolt holes.
-Leo- |
I had to use washers between my TQ converter and flexplate on my white caprice. I didn't go through as much trouble as Leo did, I just put the washers in there.
I put the washers and longer bolts in and it works great!! Thanks for the help guys. MM
| Build for Hp or Torque? | Venturat | Engine | 76 | 09-23-2008 10:22 AM |
| Torque converter and flywheel | Novaman78 | Transmission - Rearend | 8 | 01-29-2005 05:30 PM |
| Removing flywheel to converter bolts in a 1958 Chevy Impala 348 Cast Iron Powerglide | 1958imp348 | Transmission - Rearend | 9 | 11-22-2004 03:18 PM |
| Torque Converter Application | BMRIde85 | Transmission - Rearend | 4 | 06-17-2004 02:57 PM |
| C5 or Torque Converter Bad? | k2mooch | Transmission - Rearend | 2 | 11-30-2003 08:27 PM |
