Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Torque Converter to Flexplate Torque Spec. Needed - 2004R
Old 05-26-2010, 07:33 AM
Zeeb's Avatar
Zeeb Zeeb is offline
Hello,
Have a "Revmax" converter for my 200-4R that I'm bolting up to a B&M flexplate - could use a torque recommendation (will use medium strength locktite and a lock washer). Also, this convertor is actually a smaller than stock unit with a welded-on mounting ring; therefore, I have clearance behind the ring to lock the bolts with a nut and lockwasher on the backside, after they are properly torqued. Would anyone recommend against this for any reason?
Thanks!
