Torque Converter Flushing? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-14-2006, 12:06 PM
CARB TECH
Tranny flush (YES)
I worked at a lube shop for 10 years sponsored by Castrol. Out of all the years I worked there the best thing to do is flush the system in the vehicle. It gets everything out of the converter, cooling lines, pan and valve body, but make sure you find a shop that has a T-Tech machine, because that machine solely runs off of the transmission pressure, not like the old style that forced it in with an electric pump. When you do decide to flush it use full synthetic fluid, the only way to go. It has a higher volatility to burn off that means less topoffs, better hydraulic pressure and better shifting performance. My recommendation would be either Castrol, Mobil1 or B&M Redline synthetic tranny fluid. Try that and good luck. I was an ASE certified tech through Castrol and Lube 'n Go here in Las Cruces and went through training classes on conventional fluids verses synthetic fluids and I got to tell ya synthetic is the way to go. Thats all I use in my wifes '05 Taurus, better gas mileage, better startups and less wear on the battery and starter. Give it a shot it should help out alot.
Tom Lyannas
  #17 (permalink)
Old 07-14-2006, 07:55 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I removed some of the off topic posts / comments.
I sure hope that you are not including myself into this statement.
the folks invovled know who they are.
If you want to play games with posts , please take them to the Hotrodders' Lounge forum.
  #18 (permalink)
Old 07-14-2006, 09:47 PM
russlaferrera
Last wiki edit: Threading tips
Wiki Edits: 2
Flushing converter
Have the converter flushed. Normally when I rebuild a trans for myself I replace the converter.
We have a OTC converter flusher at work. I went to one of our vendors for parts with a converter that was flushed. He cut it open and showed me the sediment that was left inside
Note: I must say it was cool how the machine cut and then welded the converter again.
  #19 (permalink)
Old 07-15-2006, 02:21 PM
Without getting sucked into the age argument I would say that having instant pressure and instant fluid would be the best way to go. Without fluid for a second or two untill it is sucked into it will cause wear. Why cause needless wear?
Same as the engine oil. Since I do not have equipment to give instant oil pressure at start up from a oil change I fill the oil filter with oil prior to installation so that there will be close to instant oil after the change.
Be safer is less expensive than saying "opps".
  #20 (permalink)
Old 07-15-2006, 04:32 PM
BigDawgsEatFirst's Avatar
400SBC4Life
you are going to get some else started.
I know mechanics that will argue the oil filter filling with you.(and me for that matter)
  #21 (permalink)
Old 07-15-2006, 06:51 PM
CARB TECH
sorry everybody
I guess I am not educated enough to be here so I guess I will leave the forum. Sorry to waste everybodies time. bye.
  #22 (permalink)
Old 07-15-2006, 07:54 PM
Classix_Lover's Avatar
Music soothes the soul
Last journal entry: Wiring finished finally
um.... k??
  #23 (permalink)
Old 07-15-2006, 09:17 PM
If anybodys feelings were hurt, not my intention, but why tell a man not to do something that will not hurt but might help. I really dont have anything against young people, but it seems like they want to tell me what to do nowadays. The original poster already had trouble with his tranny, i might have said it a little better, but i didnt, but i can spell and if i ask for help i need it. I thank everyone who has went out of there way to help on my car. I remember when you had to put two matchbooks under your 8 track to hear C.C.R. again sorry if i hurt any feelings. P.S. the 70s were not that long ago were they. Wormy.
  #24 (permalink)
Old 07-15-2006, 09:49 PM
400SBC4Life
Originally Posted by Steves66
The rear clutches in my trans let go and I am needing to have the torque converter flushed since I am having the trans rebuilt. My question is, how affective is flushing the converter? Can it be done at home by pouring new fluid in and draining it back out a couple of times or until clean fluid comes out, or should I pay a shop $40 to do it? My converter has a drain plug and when I first drained it after it let go the fluid didn't look that bad. It was a little discolored, but I didn't see any signs of metal shavings in it. The trans was rebuilt less than a 100 miles ago and I have a new J&W 10" 3500 stall converter. The trans shop that done the rebuild before gave me my money back and I took the trans to a speed shop to have a good rebuild done.
what did you decide to do?
  #25 (permalink)
Old 07-15-2006, 09:55 PM
400SBC4Life
My brother always tells me of the time he left me in the car when he stopped by his girlfriends house and I got in his 8-tracks in the glove box and pulled the tape out of them.
I must have been 4 or 5 years old
I remember doing it
It kept me busy
  #26 (permalink)
Old 07-15-2006, 10:00 PM
Good thing you wasnt my brother
  #27 (permalink)
Old 07-15-2006, 10:01 PM
Good thing you was not my brother
  #28 (permalink)
Old 07-15-2006, 10:03 PM
400SBC4Life
LOL
  #29 (permalink)
Old 07-16-2006, 12:16 AM
BstMech's Avatar
NYOFP4RJ3CHRIS
See, there ya' go. If you had spent the few extra bucks and got the Sparkomatic instead of the Kraco, you wouldn't have had to use matchbooks.
Staying on topic.....
I almost always dump a quart in the convertor before install. Just the way I was taught. Of course I give my frictions a bath in fluid also, but many guys don't.
  #30 (permalink)
Old 07-16-2006, 12:23 AM
lust4speed's Avatar
My first player was a 4-track Muntz (probably not spelled correctly). Second player was state-of-art and would play either 4 or 8 track so you didn't have to dump all your old tapes. Uhh, did we get off topic again?
torque converter to flexplate bolts?? gavinpierce Hotrodding Basics 4 04-20-2006 05:25 PM
Torque converter, diesel vs gas pjd Transmission - Rearend 4 09-10-2005 09:52 PM
torque converter IDENTIFICATION 327amc Transmission - Rearend 5 03-26-2005 07:23 PM
Is my jeg's brand torque converter a dud? elukas Transmission - Rearend 5 10-07-2004 12:08 PM
C5 or Torque Converter Bad? k2mooch Transmission - Rearend 2 11-30-2003 09:27 PM
