which torque converter to get? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2011, 03:14 PM
I'm trying to figure out what torque converter to get and can use some help.
This is what i' working with:
383 C.I.D. four bolt main
Holly 750 cfm
Trick Flow heads 72cc 195cc intake runners
Cam 246/254 duration with .558" lift
Edelbrock air gap
I want to run a 700r4 and really have no clue on what torque converter to get.
Old 03-15-2011, 03:21 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
What is this 383 in and what rear gears does it have ? depending what you do with this ride i would think at-least a 2500 stall with a 9 inch converter. JMO
You could alway's call a place that builds converters and give them all you specs and they can build you what you need. JMO
Cole
Old 03-15-2011, 03:53 PM
converter
first thanks for your reply and it's going in a 69 chevelle. i have a 12 bolt rear and thinking of running 3.73 gears.
Old 03-15-2011, 04:12 PM
1984 C-10 383 SBC
I have the same engine (383), 700 R4, 3.73 gears, .540 lift cam, in my 1984 Chevy C-10. The truck weighs 4,000 lbs, and I called TCI and went with convertor part number # 243105. Ken.
Torque Converter to Flexplate Torque Spec. Needed - 2004R Zeeb Transmission - Rearend 1 05-26-2010 06:47 AM
Bellhousing bolts and torque converter bolts torque specs Davey3ch Transmission - Rearend 2 09-04-2009 11:05 AM
B&M Torkmaster 2400 rpm stall converter vs. stock torque converter??? zbhover Transmission - Rearend 2 11-02-2008 07:52 PM
Which torque converter? baspinall Transmission - Rearend 1 04-28-2006 08:28 PM
Torque Converter collinjones Transmission - Rearend 0 09-27-2002 04:06 AM
