Torque Converter Help
Hi,
I have this toyota tranny wich is made by Borg Warner, the problem is nobody makes a high stall converter for this baby and shipping it to USA to have it tweaked will cost me a lot of money, somebody told me that if I machine the impeller and turbine, or the stator in order to increase clearance, the stall speed will be raised and the converter will work fine, this is suposed to be the mod that is made by all the converter remanufacturers to create high stall units, is this correct? how much should I machine and where? it would be a drag cutting and welding it back several times so I would like to make a good estimate from the begining, I have the tooling and skills for the project, just need the correct info. Thanks a lot in advance. |
Give us some more info....
What is your stall speed now? Is this foot brake or transbrake checked? How much do you want it raised? How much motor do you have? Do you have cam specs, stroke, engine displacement, max RPM, shift points, rear gear ratio and tire size. What is your expected use for this application? What type of driving will it be used for?........... |
thanks for repying,
The tranny is in the back of a 1980 1.6 litre toyota 2T engine, it is a street car, has a mildly modified head, headers, dual carbs, stock cam, the problem is it is very slow taking off, it needs a more free revving converter, we are at 6.600 feet of altitude and all help is wanted, the specific question is if increasing the internal clearance of the converter increases the stall speed? it would be nice having it at around 3800rpm wich is a good point for clutch take offs with this same engine. Augusto. |
please don't let me fall to the bottom without an answer...
Augusto. |
so am I rigth or not, increasing the clearance does raises the stall speed or not.
thanks Augusto. |
| torque converter to flexplate bolts?? | gavinpierce | Hotrodding Basics | 4 | 04-20-2006 04:25 PM |
| Torque Converter Failure - TH350 | blown81 | Transmission - Rearend | 1 | 10-16-2005 11:41 AM |
| Torque converter, diesel vs gas | pjd | Transmission - Rearend | 4 | 09-10-2005 08:52 PM |
| torque converter IDENTIFICATION | 327amc | Transmission - Rearend | 5 | 03-26-2005 06:23 PM |
| C5 or Torque Converter Bad? | k2mooch | Transmission - Rearend | 2 | 11-30-2003 08:27 PM |
