Torque converter hybid sandwich - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2006, 07:23 AM
Torque converter hybrid sandwich
Has any one had a custom converter made up ?
I need to fit a c4 behind a non ford I6 (aussie mtr) - I've got the bellhousing sorted, but am wondering if its possible to fit a (as an example) chev TC front shell to a ford TC back shell ?
Looking for options - thanks.
Old 05-29-2006, 07:31 AM
Crosley's Avatar
Wiki Edits: 1659
The bolt pattern on the converter that meets the engine flywheel and the hub that slides into the back of the crankshaft are easy to setup for size.
Where problems come up are on depths of these areas and the over all height of the converter. All must be correct for the setup you need to function correctly.
The converter must fit the spacing between engine, tranny , any adapter(?) correctly so the trans pump gears are engaged correctly, the splines line up for the input shaft and stator support splines
Old 05-29-2006, 08:23 AM
Most converter builders make use of the parts that best fit the spacing in between the engine and trans. As Crosley stated, the heights and spacing between the engine and trans is critical for success. Accurate measurement of all dimensions will dictate your success rate. You will also need to know engine torque characteristics, engine RPM range, desired stall speed, and intended use to correctly configure converter internal parts.
torque converter to flexplate bolts?? gavinpierce Hotrodding Basics 4 04-20-2006 04:25 PM
Torque converter, diesel vs gas pjd Transmission - Rearend 4 09-10-2005 08:52 PM
torque converter IDENTIFICATION 327amc Transmission - Rearend 5 03-26-2005 06:23 PM
C5 or Torque Converter Bad? k2mooch Transmission - Rearend 2 11-30-2003 08:27 PM
What Can I Really Expect From a High Stall Torque Converter ? white66coupe Transmission - Rearend 3 05-25-2003 05:21 AM
