torque converter identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2008, 01:58 PM
chewyscool's Avatar
Big Block 454
Before I set my motor back in the bay I would like to know if anybody can help me identify the torque converter on my tranny. I have no idea of who put it in or where it came from because the car was a stick from factory. Anyway here is what I do know:
-th700r4 tranny
-splines on the converter is 24 with 3 wider ones? Does this = 27 spline? These are the splines closest to the back side of the converter.
-numbers on the converter is 102301 with the letters DEF written on it.
Does that help anybody? Maybe I need more info if I can get it. I surely do not want a high stall with the motor I built.
Old 08-05-2008, 02:30 PM
Diameter Check
I can't help you with the part# check but if you measure the diameter of the converter you might get an idea whether it's built for economy or high stall.
If it's a small diameter, like 13" or smaller it's a for sure it's probably a high stall(3,000 rpm or more maybe). Also, because most aftermarket high stall converters can be made from stock cores with modified internals, a larger converter diameter with a stock part number on the case does not guarantee it's super mild unless you know for sure it is stock to that vehicle and not modified. If you have some pictures of or have another known stock converter around to compare you might be able to see a difference in the shape of the converter on yours if it's a larger diameter high stall one. The higher stall ones usually have a much more bulbous look to them.
A local trans shop could probably be a big help on this one. If the trans is of unknown origin it is usually pretty cheap to either get the converter rebuilt at the local trans shop or buy a stock rebuilt one from a local trans supply shop. I bought one for my turbo 350 through the local shop years ago, they could pretty much tell what the stall would be by looking at the stator and impeller when it was apart. I remember years ago my wife's camaro had a front seal leak and after putting the car back together it still leaked, turned out it was a cracked neck weld on the converter. I went to a big wholesale trans supply shop and they sold me a fresh rebuilt for like $60.00, this was about 20yrs ago though. I think some of the bigger shops can actually test the converter for stall speed before putting it in the vehicle.
It's a smart bet to go with a fresh converter when it's already apart, losing a trans from a worn converter is pretty common. You can usually specify your stall speed if they are going to build one for you, usually way cheaper than the Jeggs or Summitt route if you know what I mean.
I am not sure the spline count has much to do with anything other than verifying it will physically fit into your front pump.
Old 08-05-2008, 02:36 PM
chewyscool's Avatar
Big Block 454
Thanks for that information. One more question I have is which splines do I count to Identify whether it is a 30 spline or an older 27 spline. I have 2 sets of splines on the input shaft. also the converter is 13"
Old 08-05-2008, 03:42 PM
I think I mis-spoke on the converter diameter, a 13" is probably stock diameter. 10-12" converters are the screamers. At least on t-350's, also if you want to make sure the spline count is right just try putting it into the trans. Make sure line it up with both the pump tangs(notches on the converter neck) and the input shaft. If it won't go then you know you have a problem.
Old 08-05-2008, 05:22 PM
700r4 torque converter ID
This site gives GM codes for the 700r4 torque converter
http://www.bulkpart.com/Merchant2/me...e=4L60-700R4tc
Old 08-05-2008, 06:34 PM
chewyscool's Avatar
Big Block 454
I see the code on that site and have gathered alot from it.
Old 08-05-2008, 11:38 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
The innermost, smaller shaft is the input. 27 or 30 spline. The other larger splined shaft is stationary.
Old 08-06-2008, 12:29 PM
chewyscool's Avatar
Big Block 454
thanks c10 the small shaft has 30 and the larger has 27. So I will be needing a 30 spline converter right??????????
Old 08-06-2008, 01:45 PM
C-10's Avatar
Revolution Calling
Correct. 30 splines on the shaft that is the smaller of the two.
700R4 Torque Converter Flexplate Question fosterdl Transmission - Rearend 8 03-23-2008 12:03 PM
Torque Converter Question newbielike Transmission - Rearend 2 12-17-2007 05:53 PM
Torque converter question sam83k10 Transmission - Rearend 7 08-09-2007 07:23 PM
Torque converter, diesel vs gas pjd Transmission - Rearend 4 09-10-2005 08:52 PM
torque converter IDENTIFICATION 327amc Transmission - Rearend 5 03-26-2005 06:23 PM
