Torque converter install - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2013, 12:12 PM
I have a 95 Nissan Pathfinder VG30E engine and am tying to do an engine swap , but problem is, I for the life-of-me can't get the torque converter back in the tranny far enough! Any tricks would be appreciated!
Old 04-23-2013, 12:27 PM
life is a temporary assignment
Keep spinning it as you push in on it..it should drop in about three times..
Old 04-23-2013, 03:21 PM
I have spun it both ways even jiggling it up and down for about "2hours-too-long" and it still doesn't click in wahhh! I'm at my wits end!
Old 04-23-2013, 05:44 PM
How do you know it's not all the way in ?? Did you try bolting it in yet.. Don't pull it up with the bolt's... It should turn once it's all bolted up..
Old 04-23-2013, 06:15 PM
I'm supposed to have 1.08 inches between the converter bolt holes to the edge of the bell housing (and that's what I need according to the measurements on the flex plate) and I only have 1/2 inch. Yes I tried putting the engine up to it and it comes against the torque converter 1/2 inch before the bell housing.
#Pullingallmyhairout
Old 04-23-2013, 07:24 PM
Last wiki edit: Window removal and installation Last photo:
Wiki Edits: 11
One thing I do on particularly sticky ones is grab on both sides of the converter with my fingertips and pull back out slightly, turn a tiny smidge then push back in. Repeat repeat repeat as needed or until you get sick of it.
95 pathfinder, install, torque converter, tranny, transmission swap
B&M Torkmaster 2400 rpm stall converter vs. stock torque converter??? zbhover Transmission - Rearend 2 11-02-2008 07:52 PM
vibration after torque converter install dawg Transmission - Rearend 4 03-29-2008 03:42 AM
torque converter install questions dawg Transmission - Rearend 5 03-21-2008 05:13 PM
torque converter install ragincajun19 Transmission - Rearend 3 04-24-2007 10:22 AM
Torque converter install connera Transmission - Rearend 7 05-16-2005 08:11 PM
