Torque converter install
Ok, my first trans rebuild is complete, and I am installing the converter. Before I put it on, I am able to turn the input shaft and the output moves. Once I get the converter to seat, and I have about 1 1/4 from the end of the bell housing and the face of the converter, the converter spins smoothly, but the output does not move. Am I seated? I felt it seat 3 times, grabbing the splines. I tried to get it to seat more, but It seams to be in all the way. Am I missing something here?
It is a 69 Powerglide, by the way. Thanks. |
Thanks Vince
So Vince, am I ready to bolt to the flex plate?
Andrew |
Vince |
thanks
Excellent! I will do that this Saturday! Thanks for the help.
Andrew |
Did you put any trans fluid in the torque converter before you installed. The last 2 I installed said to put a quart of fluid in the converter before installation. Also watch your spacing between flexplate and converter. If it is too much it may not let the pump engage properly.
As an example the exception to this rule is: mopar 904 - 727 type trannys. On the dip stick mopar tells you to check the fluid level in neutral, engine running. That is due to the fact that these mopar trannys do not fill the converter while in 'park'. Most other trannys pump the converter full in any shifter position. This subject has been beat to death. thread is closed.
At the Bonneville Salt Flats, first gear is known as 130 mph. Last edited by Crosley; 05-16-2005 at 08:16 PM. |
| torque converter IDENTIFICATION | 327amc | Transmission - Rearend | 5 | 03-26-2005 06:23 PM |
| Is my jeg's brand torque converter a dud? | elukas | Transmission - Rearend | 5 | 10-07-2004 11:08 AM |
| Torque Converter Application | BMRIde85 | Transmission - Rearend | 4 | 06-17-2004 02:57 PM |
| C5 or Torque Converter Bad? | k2mooch | Transmission - Rearend | 2 | 11-30-2003 08:27 PM |
| What Can I Really Expect From a High Stall Torque Converter ? | white66coupe | Transmission - Rearend | 3 | 05-25-2003 05:21 AM |
