torque converter install questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2008, 05:53 PM
dawg's Avatar
NAVY VETERAN
installed my new TCI torque converter today .
I got the triple thud as the splines engaged.
measured the distance from bellhousing to converter pads and it was good.
bolted to flexplate with no problem.
gear selector in neutral but converter doesnt spin freely as per TCI instructions?
spins one way ok but not the other way?
maybe im reading into this wrong cuz the motor is hooked up to it and im using my flexplate tool to rotate.
engine and all
Old 03-19-2008, 06:12 PM
Holder350's Avatar
Auto Parts Professional
the motor (epecialy if its broken in) will be hard to rotate in the reverse direction.
you should be fine, if the converter went all the way on and everything bolted up without trouble you should be fine.
Old 03-19-2008, 06:46 PM
T-bucket23's Avatar
Wiki Edits: 26
engine and all
If the converter is bolted to the engine you are past the "should spin freely part.
Sounds like you should be fine
Old 03-20-2008, 11:06 AM
The spin freely part is before you bolt it to the flexplate, if you were able to turn it to line up the bolts you are ok.
Old 03-20-2008, 05:04 PM
dawg's Avatar
NAVY VETERAN
yes TCI said it was kind of a typo but since been corrected.
the converter spins with no problems .
thks guys!
Old 03-21-2008, 05:13 PM
Another simple trick when bolting everything together is to make sure you have to move the converter forward to bolt it tight to the flywheel. That always works for me.
Torque converter won't fully seat in transmission Mystic95z28 Transmission - Rearend 3 09-12-2007 09:07 PM
Torque Converter Flushing? Steves66 Transmission - Rearend 34 07-26-2006 10:12 AM
bop th400 torque converter? meev182 Transmission - Rearend 2 04-24-2006 10:25 AM
Torque converter install connera Transmission - Rearend 7 05-16-2005 08:11 PM
Torque Converter Question 79 Malibu327 Transmission - Rearend 2 05-27-2004 12:44 PM
