Torque converter leaked out fluid?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2006, 09:51 AM
84Z 84Z is offline
Gas Raper
So my car was being trailered to my friends shop to get fixed and as it was geting dragged onto the trailer, there was red fluid that was dripping from somewhere. At the time, I thought it was from the transmission because I left the drain plug unbolted, but thinking back on it, when I put my engine, trans and converter on and jacked the engine up to put it into my car, the converter leaked fluid out. I was wondering if this was normal, probably not, and is there like a gasket that goes between the converter and trans that I forgot about? Or if the circulation of fluid in the transmission puts some fluid into the converter too? Because my car's not running at the moment, how would I be able to tell if the converter did leak out the fluid? It'll have some obvious affects while driving the car, probably feel very sluigish if not break? And what do you think I should do about this? Thanks.
Old 08-13-2006, 10:07 AM
1939d2/s10's Avatar
Thers is a transmission shaft seal that is mounted on the transmission for the convertor.Is this a new transmission ? Also I would crawl underneath and look for fluid thats dripping from anything then try to trace to its origin,Johnny
Old 08-13-2006, 09:32 PM
84Z 84Z is offline
Gas Raper
Brand new transmission, and it was only when my car was dragged onto the trailor, it's been sitting for like a month now.
B&M Torque Converter my350camaro84 Transmission - Rearend 4 07-07-2005 09:24 PM
Torque Converter Problem? 38project Transmission - Rearend 5 06-05-2005 02:21 AM
torque converter upgrade to avoid detonation? darom Engine 35 05-23-2005 06:48 PM
destroyed 1 torque converter hotrodjohn Transmission - Rearend 3 04-17-2005 11:23 AM
Torque Converter Question 79 Malibu327 Transmission - Rearend 2 05-27-2004 12:44 PM
