Torque Converter Lockup 700R4, Automatic Operation - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2011, 09:11 AM
Rectum? Damn Near Killed Um!
Hey guys, and gals! Just wondering if anyone had any thoughts on the Superior/Fairbanks Torque Converter Lockup kit. I talked to the guys at PATC and they said it just senses through pressure when to take the lock up out. I know there are TONS of kits out there to do this, and tons of guys that just wire it up to a switch. I don't want to have one more thing to remember while driving, so i wonder if this kit is any good or if someone has a diagram of how they wired it up for automatic operation. The vehicle is a 91 chevy Truck 2wd, converted to run all carb, it did have cruise at one point so im sure the brake pedal is the four prong style. Any help would be great thanks!
Old 11-04-2011, 10:32 PM
SSedan64's Avatar
Lockup Info >> http://www.rowand.net/Shop/Tech/LockupTCCWiring.htm
Superior/Fairbanks K013 kit is just a few Brass fittings, wire & a 4th Pressure switch. It Lockups up the TCC after the 4th gear shift. Unlocks with 4-3 downshift & Brake Pedal depression. Can be annoying if used without a Vacuum switch or Toggle switch for manual control/operation around town.
700r4 Torque converter lockup coming on and off chevy_c10 Transmission - Rearend 4 05-04-2010 07:43 PM
700r4 lockup converter questions 71/454 Transmission - Rearend 2 01-17-2010 08:36 PM
Torque Converter Lockup at Low Speeds JohnTN Transmission - Rearend 5 09-15-2005 06:05 PM
raising torque converter lockup hueysrod Transmission - Rearend 11 06-10-2005 09:26 PM
How much torque can a turbo350C (lockup converter) take? supercab78 Transmission - Rearend 3 02-28-2005 06:00 PM
