Torque Converter play - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2007, 11:27 AM
70bird's Avatar
Smile if you know Jesus
Last journal entry: Waiting for a tranny
I was recently doing an engine swap on my blazer and I noticed that the torque converter was able to rock up and down or side to side when disconnected from the engine. There is about 3/8" movement.
This doesn't seem right to me. I don't recall being able to do this with my previous chevy.
This is on a th350. The trans doesn't seem to have any problems. I've been running it for 4 years now. I have always felt that it is a little loose in reverse but it has been consistent over the last 4 years.
Should the fully engaged torque converter be able to rock on the input shaft when not attached to the flexplate?
Old 03-29-2007, 12:07 PM
fast68's Avatar
likes chevy trucks & boobies
yes it can rock on the input shaft
to a degree
make sure the converter is fully engaged into the pump
two sets of splines and the two pump cut outs/notches
if theres not a gap inbetween the converter(front side of it)and the backside of the flexplate then its not all the way in or the plate is instaleld onto the crank backwards possibly
good luck
Old 03-29-2007, 07:23 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
there will be some movement..... this is normal.
The front of the converter has a hub that engages into the back end of the engine crank shaft. That provides the proper alignment.
Building a SBC to rev to 8k, and have power Andyrew Engine 52 04-17-2006 12:46 PM
Torque Converter Failure - TH350 blown81 Transmission - Rearend 1 10-16-2005 11:41 AM
Torque Converter Lockup at Low Speeds JohnTN Transmission - Rearend 5 09-15-2005 06:05 PM
Torque converter, diesel vs gas pjd Transmission - Rearend 4 09-10-2005 08:52 PM
C5 or Torque Converter Bad? k2mooch Transmission - Rearend 2 11-30-2003 08:27 PM
