My 83 Silverado has a 355 sbc and a th350 trans in it. The torque converter I bought(and I probably shouldn't have) was supposidly a knock-off B&M with a 2200 to 2400 stall. It never has stalled out at all and works like a stock converter. Could a faulty converter cause a torque loss off the line? I don't know how the inside of these things work. Seems like my power isn't getting back to the wheels.
How is that 355 built? Has it been on a dyno? It won't stall if the engine doesn't have the power and an engine with more torque will make the same converter stall higher.
It all needs to match the total package-engine, rear gears, weight...etc.
I'm in the middle of a head change but I had 461 heads on it, xe268h cam, performer rpm intake, 650 dp, and an eagle bottom end with flat top pistons. It's in a 83 4X4 truck with 3.08 gears and 31" tires. I would think I would at least be able to stall this converter out. I've played with timing and still no tire fire. Just read an article in knowledge base and now feel like a dumb@$$ for asking my question.
What do you mean you cant stall the converter out?? Where ever the RPM sits when you do a brake torque IS the stall speed. Either it's stalling to high or too low. Which is it?
Its not stalling at 2200 to 2400 rpm, more like 1200 rpm. I want to do 3.73's gears but time and cash are coming short so it'll have to wait. I bought the 2200-2400 stall so I could get more power off the line but since it's not stalling out all the way it's supposed to I can't even break tire, 2500rpm and above it really pulls hard. Gears are killin me, I can go 65 mph in first gear!!!!!
Either of two things will cause a low stall. Bad converter or not enough power to "push" the converter into stall speed. Gears will affect your launch but have nothing to do with stall speed.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
