Torque Converter question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2008, 02:58 PM
Hey guys this might seem like a dumb question but I am new to this. I am currently replacing the torque converter on my TH350. Do I need to fill the new torque converter with transmission fluid before splining it on to the input shaft? I am guessing that I will not need to as the transmission fluid pump will fill it I believe. Any help here greatly appreciated, Thanks!!
Keith
Old 04-10-2008, 03:04 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Keith
the pump fills the converter... there is a constant flow of fluid to cool the converter.
Old 04-10-2008, 03:22 PM
i would still put a quart of fluid in it
Old 04-13-2008, 06:12 PM
your ok with the torque converter.just add 3 to 4 quarts into trans for converter
Old 04-13-2008, 07:06 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I like to put a couple quarts in the converter. When you're filling a dry tranny before startup, it only holds a few quarts in the pan, so until you get things up and running, it has drained all the oil out of the pan and deposited it in the TC. For that reason I fill the TC and the pan as well. That way you have a little more lube to play with for first startup.
Old 04-13-2008, 08:28 PM
life is a temporary assignment
Like it's been said,I would put a couple of quarts in the converter before installing.
Torque converter question. gavinpierce Hotrodding Basics 1 02-15-2006 09:53 AM
Torque Converter Failure - TH350 blown81 Transmission - Rearend 1 10-16-2005 11:41 AM
Torque converter, diesel vs gas pjd Transmission - Rearend 4 09-10-2005 08:52 PM
I'm so dumb. (torque converter question) raidmagic Transmission - Rearend 11 03-07-2005 08:29 PM
Torque Converter Problem Madhawk Transmission - Rearend 4 11-23-2004 08:35 PM
