Torque Converter Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2011, 02:53 PM
No End Clearance,on Converter
Is The Converter New? If It Is,could Be Too Tall Of Hub,or Could Be Object In Pump,restricking It From Going In All The Way,also Make Sure Nothin Is In Crank Shaft Hole,like A Ring From Previus Converter,or Pilot Bushing,thats All I Could Think Of,good Luck!
Old 02-13-2011, 03:01 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Sir;
Welcome to Hotrodders.com
read dates on threads when you search. You pulled up very old thread
Old 02-13-2011, 03:03 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
4yr old thread i hope he has got it fixed by now. If you look at the top left of the post you are going to post on there is the date so we know just how old the thread is. But i will have to admit some of the old threads need to come back every now and then. JMO "But you left some good info for others to see when searching for answers."
Cole
