Torque converter question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2013, 09:30 AM
71K20chevy's Avatar
If I put a 3600 stall converter in a 4L80E, would it still be drivable? My guess is yes since it has lockup, but I'd just like to make sure. Thanks!
Old 11-20-2013, 10:55 AM
astroracer's Avatar
Where did you get the converter? I would call the maker and talk to them. They will want to know EVERYTHING about the vehicle you are putting it in so have all of your engine specs, trans, gear ratios and tire sizes on hand.
We can't do anything to help you without all of those anyway but you will do best to talk to the people who built it.
Mark
The Following User Says Thank You to astroracer For This Useful Post:
AutoGear (11-29-2013)
Old 11-20-2013, 11:19 AM
71K20chevy's Avatar
Haven't bought it yet. It'll be going in a 71 K20, 5000 lbs with 33" tires and 4.09 gears. It'll have a 6.0 Vortec with around a 228* cam with 400-450 hp.
Old 11-20-2013, 11:47 AM
astroracer's Avatar
Good, choose a couple of manufacturers and give them a call. They are going to need cam, carb and just about every other piece of info you can think of. Look at a couple of sites online and fill out their check lists.
This is the best thing you can do.
Mark
Old 11-20-2013, 04:53 PM
OAE 152's Avatar
Most after market converters don't offer lock up in that high of stall so I would check with the manufacturer to make sure it still has a lock up clutch in the converter. Just sayin'
Old 11-20-2013, 06:19 PM
Proud LOSER
I have seen this used in a truck with a healthy BBC on a small hit of gas, works well and was very driveable. Flashes right around 3500-3700 in this case.
http://www.summitracing.com/int/part...make/chevrolet
I'm not a huge fan of off the shelf converters for a serious performance application but this one has been working well.
Old 11-26-2013, 01:33 PM
Ozz1967's Avatar
Air Force Guy
If you're going to get a converter, get a purpose built one. Precision Industries, ATI, Circle-D....
Stay away from the likes of B&M and TCI. TCI and B&M may have been good in the past but for the past 4-5 years their Quality Control seems to have taken a real hit as their return rates have skyrocketed.
Torque converter: if you have a question this might help painted jester Transmission - Rearend 1 01-13-2012 07:46 PM
Torque Converter Question sirlotsoflovin Transmission - Rearend 2 02-13-2011 03:03 PM
Another Torque Converter Question 68Birdman2 Transmission - Rearend 3 10-27-2009 08:57 PM
Torque converter question sexypizzaman Engine 6 03-17-2009 02:34 PM
Torque converter question(s) chrisflock Transmission - Rearend 3 11-10-2006 11:41 AM
