Torque Converter Recommendation - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2005, 09:49 PM
tc33's Avatar
Stuck in the 30's
Last journal entry: Where it came from and how I got there - a short Summary
OK, here's the scoop, I have a 350 SBC 435/435 with the following setup
edelbrock air gap manifold with 800 cfm carb
edelbrock cam 2204 234/234 @.050, 359 lift
TH 350 trans
ford 9 inch rear with 3.70 gear ratio
This is all going into my 1936 chevy master 2 door sedan.
Anyone suggest the correct torque converter ??
I'm thinking TCI street fighter 10" 3000 rpm stall. Am I right on, close, out in left field ??
Need additional info, let me know.
Old 03-18-2005, 12:56 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
covertor
Crane has a similar cam and they recommend 3000 stall but recommend much lower gears. Personally I think your carb is way too big. I wouldn't run anything bigger than a 700. I have a 454 with a similar cam. I only run a 750 on it.
Old 03-20-2005, 06:26 AM
converter
If you are all out racing you may have a good setup but if you are driving it on the street I can't see a 3000 rpm converter. Also your carb is WAY too big. KEITH
torque converter IDENTIFICATION 327amc Transmission - Rearend 5 03-26-2005 07:23 PM
Is my jeg's brand torque converter a dud? elukas Transmission - Rearend 5 10-07-2004 12:08 PM
Torque Converter Application BMRIde85 Transmission - Rearend 4 06-17-2004 03:57 PM
C5 or Torque Converter Bad? k2mooch Transmission - Rearend 2 11-30-2003 09:27 PM
What Can I Really Expect From a High Stall Torque Converter ? white66coupe Transmission - Rearend 3 05-25-2003 06:21 AM
