torque converter spline ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2007, 12:23 AM
the dan's Avatar
83 chevy c10 long bed
so my buddy is getting a new torque converter for his 700r4, and they have 2 different spline options to choose from, one is a 27 and the other is a 30
well his 700r4 has 2 spline sets on the imput shaft, the larger one is 27 and the smaller one is 30, any clue what t/c to use?
Old 07-14-2007, 08:32 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the spline count difference is for the input shaft spline count... the input shaft is the smaller one that rotates. The "fixed" ( does not rotate) splines are for the stator support inside the converter.
Old 07-14-2007, 09:44 AM
the dan's Avatar
thank you very much
Building a SBC to rev to 8k, and have power Andyrew Engine 52 04-17-2006 01:46 PM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 08:36 AM
Leaky torque converter?? 84Z Transmission - Rearend 6 03-04-2006 06:17 PM
Torque Converter Failure - TH350 blown81 Transmission - Rearend 1 10-16-2005 12:41 PM
Torque converter, diesel vs gas pjd Transmission - Rearend 4 09-10-2005 09:52 PM
