Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Torque converter stall help needed
Old 01-24-2013, 11:02 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
You will need a custom built converter designed to give about a 3200 stall speed behind the 327.
You want a "lock up" style converter based on a 245MM case diameter. You don't have near enough gear in the car.
Get some 4.10's and overdrive will have a usfull purpose and the car will be a lot more fun.
The lock up function allows the overdrive to function properly for efficient cruising .
Home | Precision Industries
Yank Performance
The Following User Says Thank You to F-BIRD'88 For This Useful Post:
64nailhead (01-25-2013)
