Torque converter Stall and ID questions
Hey guys I'm switching out my low stall stall converter in my th400, I have a th350 with what I believe is a higher stall although there's no markings, this converter is blue in colour and only number I see is 737. Now does diameter indicate stall speed?
that list only kinda works..
it's a good base line.. for off the shelf units.. all bets are off, otherwise.. my 10" is a 4800 stall.. |
thought this might help
http://www.hotrodders.com/forum/atta...id=62749&stc=1
I thought this might help. Its the internal configuration not the case diameter that decides basic eng torque stall speed. As the attachment says you could buy an advertized stall of 2500 and it would have a stall of 2500 with a stock or mild engine build, but the same 2500 stall converter could have a stall of 4000 or higher with a really high torque engine. Most people buy the wrong converters because this is so misunderstood and kill the performance they could have had and never realize it. Call the company of the converter your thinking of running and they will tell you what characteristics it will have with your particular build! Jester |
Just giving the OP an idea of general sizes used.It's always best to have a TC built for your combo but, most don't know or can't afford the extra $$. What Slip % are you getting up top with the 10"? At that stall level a 9.5" or 9" would be more efficient. Todd |
about 200rpm 300 on the button, but the 10" doesn't give away myset up.
guy looking over my rig before a "drive" basic 350q-jet and a 10" converter, nothing to see here, sleeper ![]() grudge nights are great |
| Stall Speed torque converter questions | 79camaro61601 | Transmission - Rearend | 3 | 07-31-2011 09:30 AM |
| Stall Vs 400 torque converter | mahoho | Transmission - Rearend | 5 | 09-14-2009 06:51 PM |
| Do I need a stall torque converter?? | 75GMCman | Transmission - Rearend | 4 | 05-11-2009 07:37 PM |
| B&M Torkmaster 2400 rpm stall converter vs. stock torque converter??? | zbhover | Transmission - Rearend | 2 | 11-02-2008 07:52 PM |
| stall torque converter | beetle9 | Transmission - Rearend | 11 | 12-28-2002 04:34 PM |
