Torque Converter stall RPM questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2012, 08:24 PM
Ok i have a jegs 2200-2700 stall converter. when i hold my foot on the gas and break my tiers start to spin around 1600 RPM real slow. isn't my tires suppose to brake loose in the 2200-2700 RPM range
Old 09-06-2012, 09:33 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I edited the thread title to provide more information in the thread question than the word " Help!" provides
The Following User Says Thank You to Crosley For This Useful Post:
the82elco (09-06-2012)
Old 09-07-2012, 12:41 AM
SSedan64's Avatar
Brake Stall will vary greatly depending on how well your Brakes hold the vehicle etc.....
What rpm does it Flash Stall at?
Stall Info >> Automatic Transmission & Torque Converter FAQ - TCIŽ Auto
Old 09-19-2012, 07:23 PM
TWX TWX is offline
A torque converter can still deliver power below its published stall speed, the stall speed has more to do with an optimal amount of power transfer, not that any power transfer happens.
When you open it up from a stop, the RPM at which the car really feels like it takes off at is essentially the stall speed, rather than the speed that it starts to move at.
The Following User Says Thank You to TWX For This Useful Post:
the82elco (09-19-2012)
Old 09-19-2012, 11:34 PM
One of the easiest ways to check "flash" stall is in 3rd. gear at low speeds, just push hard/abruptly on the peddle & watch your tach, you'll see by the feel of the car pulling & the tach will lay flat when you reach this point, You have 2 types of stall in a converter, brake stall (light load) & flash stall, converters are rated at flash stall (high load), I have a 2800 Jegs converter & depending on the road condition i can sometimes break the tires loose at 16-1800, other conditions it could be as high as 2200 before the tires break, but in 3rd. gear it'll flash too 28-3000.
The Following User Says Thank You to LJM97Z For This Useful Post:
the82elco (09-20-2012)
Torque converter Stall and ID questions strokin Transmission - Rearend 5 02-07-2012 08:20 AM
Stall Speed torque converter questions 79camaro61601 Transmission - Rearend 3 07-31-2011 10:30 AM
Do I need a stall torque converter?? 75GMCman Transmission - Rearend 4 05-11-2009 08:37 PM
B&M Torkmaster 2400 rpm stall converter vs. stock torque converter??? zbhover Transmission - Rearend 2 11-02-2008 08:52 PM
Wondering about accelerating RPM's with High stall torque converter 87Camaro Transmission - Rearend 3 07-28-2004 04:02 PM
