torque converter stays locked up at idle - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2012, 07:50 AM
hey guys I beleave my torque converter in my 350c is staying locked up when I come down to an idle, I have to set the idle at 1300 rpm in order for it to stay running at 700rpm in drive, any suggestions?
Old 03-24-2012, 10:13 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
What vehicle? What is the weight?
You mention mild 350 chevy engine build in other threads.
Is this a T-bucket or steel full body car?
If the converter clutch was locked the engine would die - not run,
Old 03-24-2012, 05:31 PM
psbaker75's Avatar
I had a similar issue using a stock converter with a cam that spec'd a 2200 stall, swapped converters and the problem went away. Not sure if this is what's going on for you, but I thought I would give you my 2 cents
Old 03-24-2012, 07:35 PM
SSedan64's Avatar
That does sound like a Light weight car / low Stall TC problem.
Does it want to creep forward while stopped and rpms drop too low?
Lockup shouldn't be a problem after it drops out of 3rd gear.
Old 03-25-2012, 08:08 AM
I have to set the idle at 1300 rpm in park in order for it to idle at 700rpm in drive, and it feels like it still want to move when at a stop light, its a very mild motor should be able to idle 900 in park 650 in drive no problem, I just ordered a 2200 stall converter plan on installing it this week hopefully thats my problem
Old 08-05-2013, 09:22 AM
I have the same problem. Mine is a 350 motor with mild cam, 350TH. Did the new torque converter solve your problem?
Locked up 350---torque converter bolts vetteman2 Engine 2 03-26-2011 07:23 PM
4l60e torque converter locked acdcontheroad Transmission - Rearend 2 09-14-2010 07:35 PM
torque converter locked up acdcontheroad Transmission - Rearend 5 07-18-2010 06:26 PM
won't idle after torque converter installed trblmker Transmission - Rearend 7 06-03-2009 04:17 PM
turbo 350 torque converter locked up biggy72 Transmission - Rearend 20 06-08-2008 11:14 PM
